Help with a belt
  • bizzaro megomauler
    WANTED for card bending
    • Apr 26, 2008
    • 1052
    Help with a belt
    I cast a belt for a custom with resin, no the best Idea, not pliable enough to work with smooth on 300, what else can I use?
  • renegade
    • Mar 16, 2010
    • 353
    I use those thin plastic colored student binders. I cut the shape and then ose a hole punch one one side and cut the other end into an arrow shape. fits and looks like a mego.
    • boynightwing
      That Carl Guy
      • Apr 24, 2002
      • 3382
      I never thought to use those binders! Great idea!
      I've been using this craft foam. Its a little thick but its bendy and comes in all kinds of colors.
      http://www.ssww.com/item/assorted-cr...d=2176&aid=GDT
        What belt is it?
          I use ProCreate. You can adjust the amount of hardening compound to reduce or increase flexibility. I have made Teen Titan Robin boots and gloves with it, for example...I'm really happy with it.
          You can read about it here:
          ProCreate Epoxy Sculpting Putty - Gray (x1 set) 2.50 oz. - PROCREATE
            • Apr 26, 2008
            • 1052
            Originally posted by ctc
            What belt is it?
            custom made secret till the reveal!
            • Chris
              • Dec 23, 2009
              • 2279
              That is an incredible idea! Thank you so much for sharing.
              • jessica
                fortune favors the bold
                • Nov 5, 2007
                • 4590
                Wow that's cool. I never knew about that product! It has lots of possibilities.
                To do list:
                  • 20368
                  I love both the thin poly binders/dividers & the vinyl-clad binders--so Megoesque. Great for belts, & the vinyl can be used for capes, collars, trim.
                  Beach toys/balls are good, too.
                    Yes Jessica, it is wonderful stuff.
                    • renegade
                      • Mar 16, 2010
                      • 353
                      I make the belts as I said, and the vinyl binders I buy and cut the vinyl off to restore 70's star wars capes. Make a pattern, use a hole punch for the arm holes which is too small of corse. Then pull the star wars figures arms through the holes and the arms make the perfect hole for you.
