Removing paint stains from mego outfit
  • Jetjungle75
    • Jan 11, 2013
    • 720
    Is there a way to safely remove what appears to be red paint/nail varnish from a Mego WGSH outfit?
    Thanks in advance.
  • rf-harris
    • Jan 8, 2018
    • 6
    I am not very sure about this, but I guess you can try nail polish remover. It might help.
    • Plastic Vulcan
      • Apr 25, 2019
      • 28
      I know this was posted years ago, but for anyone reading this, nail polish remover is a horrible idea. You will burn holes in your MEGO's clothes. Try soaking for about an hour in stain remover like Oxi-Clean and if that doesn't work use more invasive methods like a dab of lighter fluid on the spot.
      • Doctor Dim
        • May 18, 2017
        • 32
        You're totally wrong on this. Acetone isn't caustic. Actually, chlorine bleach can do a lot more damage than acetone.
