Sucuri Website Firewall warning??
  • TheXFactor
    • Oct 31, 2013
    • 173
    I was just trying to make a post in the Auction Watch section, but kept getting a "Sucuri Website Firewall" warning which prevented the post from going through. I made a post in the Mego Marketplace on October 25th (and just made two others as well), so it's not like my Log In was bad or anything like that. Anybody else experience this?
  • Confessional
    Maker & Whatnot
    • Aug 8, 2012
    • 3391
    Yes, I've had that happen too.
    In my case it was caused by including something odd in the post. For example, non-English language characters or the wrong type of image link code.
    • TheXFactor
      • Oct 31, 2013
      • 173
      I was including both the html from a completed eBay auction as well as a link to the figure's corresponding WGSH Gallery page here on the Museum website. I'll try reposting later with just the eBay link and see if that makes any difference. Thanks for the input.
      UPDATE: I reposted without the html link to the corresponding WGSH Gallery page here on the Museum website, and it went through no problem. So again, THANK YOU for the input!!
        • 11465
        i get that warning a lot when i try to go in and read a post. it just won't let me in
        • TheXFactor
          • Oct 31, 2013
          • 173
          Are you signed in at the time?
            • 11465
            signed in to the MM? yes, i am. just for some reason, randomly it appears, i cannot access certain threads/posts
            • TheXFactor
              • Oct 31, 2013
              • 173
              I can't even begin to figure out why that's happening to you. Like I mentioned, my problem turned out to be related to what Confessional wrote above (the wrong type of image link code). If it's happening to you when you're just trying to read a post, the only thing that comes to mind is that- maybe- there's something entered as a response (that never went through and is still pending) which is causing the same kind of problem. Maybe try the old standby of clearing cache/cookies and see if that has any effect?
                • 11465
                no, if i cannot access a thread, then i cannot access it ever
                • TheXFactor
                  • Oct 31, 2013
                  • 173
                  I don't know what else to suggest. The help request I originally sent to the website administrator over two weeks ago has gone unanswered, so I wouldn't recommend that as an option.
