Help with graphics card
  • JDeRouen
    Author of Small Things
    • Jun 14, 2001
    • 16572
    Okay, I bought a snazzy, new video card, but the video card requires being plugged into the computer power supply - however, I don't have any available power cable connections to which to attach it. What do I do?
    Thanks,
    Joe
  • spiderrogue
    new mego-er
    • Feb 3, 2008
    • 0
    buy an adapter that will plug into the existing power cable(inside the pc...usually white)..and it should give ya one or two more plugs....if i am guessing right, then that is what you need...looks something like this..but instead of black, they are all white...unless this is the actual kind that you need..lol...
    Newegg.com - Nippon Labs 4-Pin PC power to 2 x SATA Converter Cables Model POW-SATA-2 - Cables
    • Zemo
      Still Smokin'
      • Feb 14, 2006
      • 3888
      Yes,It's just a spliter Joe.
      • WannabeMego
        Made in the USA
        • 2170
        I agree with the above with one word of caution...make sure the devices connected to the power supply don't exceed it's capacity.
        You would need to research each component connected...it should state the amount of juice it will pull or require.
        This may no be an issue with newer systems as it is with older, but these newer graphics card that require their own power is quite new and not factored into minimum power requirements for pre-built systems.
        Hope this Helps.
        • jimbutsu
          Memory *is* RAM!
          • Apr 11, 2002
          • 4158
          It's definitely an issue with newer systems... maybe even a bigger issue. A lot of low to mid-end systems come stock with 300-350 watt power supplies... basically the basre minimum to handle whatever they come with. Not knowing what Joe's got, it may or may not be an issue, but it's most certainly worth checking out.
          "If you take a dog which is starving and feed him and make him prosperous, that dog will not bite you. This is the primary difference between a dog and a man."
          - Mark Twain
