Need Help Fitting Head on 6 inch Body
  • filmation batman fan
    The Man of Many Voices
    • Aug 30, 2005
    • 964
    I ordered parts from Classic TV Toys to make a first appearance Robin with removable mask. The only problem I have is trying to get the Dick Grayson head on the 6 inch body and I can't seem to get the neck plug in there. Any suggestions?
    Lurking About
    • 34218
    hot water? IS the head meant to go on the 6 inch body?
      • Aug 30, 2005
      • 964
      Not sure. I know it's the traditional Dick Grayson head. I'm not sure if the first appearance Robin head is smaller or the same size.
      • comicmike
        • Sep 22, 2009
        • 1824
        Open up the torso-neck's hole: I always find those FTC teen body neck holes too small. Either Dremel it, or carefully with turning an X-acto blade inside the hole to widen it.
        Another tip is trimming back the lip from the bottom part of the Robin's neck (X-acto; nail clippers; sandpaper).
        When the parts look more right, it can be helpful to heat both the head and the neck-hole/upper torsos with hot water before insertion.
