Need help mounting a head Flatt style.
  • QDOGG
    • Jan 13, 2007
    • 1115
    Howdy all! I bought one on Laurie's awesome Santa heads. I was wondering the best way to mount it. I am going to use an original Mego fat body as my base. I don't want to "F" it up so any and all advice greatly appreciated.
    Wayne
    Lurking About
    • 34218
    Does it have a mego type plug on it?
    • Megospidey
      Museum Webslinger
      • Jul 26, 2006
      • 5305
      Wayne,
      You are going to have to build up the neck a bit with some kind of putty or apoxie sculpt first.
      I wouldn't do this figure with a "Flatt" style head. He's really not an "action" figure.
      What I would do (and probably will do) is make a tubular neck out of putty that is the same diameter as the neck hole of the Mego torso that I'm going to use. That way you can slide the neck plug into the neck hole.
      It will allow the head to turn side to side - which is what most Megos do.
      Hope this helps!
      • ABMAC
        User
        • May 16, 2002
        • 9665
        Wayne,
        Hope this helps!
        This will severely limit his ability to fire a rifle from the prone position.
        • Megospidey
          Museum Webslinger
          • Jul 26, 2006
          • 5305
          Santa doesn't need to fire a rifle...he lets his reindeer do his dirty work. Just ask grandma.
          • UOBob
            Mostly Harmless
            • Jul 18, 2006
            • 751
            Santa and his reindeer were laughably weak and slow.
            мое судно на воздушной подушке полно угрей
