Help with body swapping
  • JMC
    • Feb 3, 2004
    • 1940
    Hi,
    I just needed some advice on how to swap the mattel GL lower arms and hands to a Castaway body. Should I cut the peg that attached the lower arm to the upper and if so, what size peg should I use to attach it to the Castaway upper arm?
    Any help would really be appreciated.
    • 11175
    Boil the arm and pop the pin out, then boil and replace with new forearm.
    • JMC
      • Feb 3, 2004
      • 1940
      Thanks that helped, I am guessing use a styrene rod for a pin....the pin that came with it doesn't seem to work well with the castaway arm.
