Lion rock head on a Mego body...???
  • KingKickass1983
    • Jan 19, 2019
    • 809
    I've been wondering, since Lion rock heads look large on the bodies they come on....do they look normal size if on a Mego scale body?
    I've an idea for a custom...just want to make sure before I purchase a Lion rock figure..
    Wanted:
    Diamond select Spider-man hands. Long shot, I know...but ya never know..
    • 9145
    I have an original Talos, but I dare not remove the head from the Lion Rock size body to compare.
    I am not 100% sure, but I think the neck hole on the 8 inch bodies are wider, the Lion Rock head would be loose and wobble around. The Lion Rock neck plugs I believe are smaller.
    • KingKickass1983
      • Jan 19, 2019
      • 809
      That wouldn't be a problem. If the head looks normal sized on an 8 inch body, I'd be fitting it with a neck peg from ctvt as I'm going to use a type S body.
      Wanted:
      • apes3978
        • Nov 19, 2005
        • 5213
        I always thought the Lion Rock heads looked pretty much in scale with the bodies.
        I am pretty sure that the Lion Rock heads would look too small on an 8" Mego body.
        • apes3978
          • Nov 19, 2005
          • 5213
          You're correct about that: The neck hole on a standard 8" Mego body is wider/larger than a Lion Rock body.
            • 11172
            I know that shrinking a Mego head with acetone makes it fit perfectly on a Lion Rock body. I've done it with a few heads.
