HELP! I need help to remove dye stains!
    • 5683
    I need some help to remove some dye stains from my DM body.
    The stains are just below the knees, and they come from a pair of hand dyed trousers that it was wearing.
    I had removed the trousers, and discovered the dye stains.
    I think it happened because the top rim of the boots applied pressure to that area, and now the stains are deep.
    I tried using the Mr. Clean Eraser and nail polish remover, but no dice.
    Has anyone else run into this kind of problem?
    What should I use? Hydrogen Peroxide? Removezit? Or just put a pair of jean on him and forget that the stains are there?
    • 20390
    You're going to have to dress the figure & just forget about it--I've had the same problem with vinyl G I Joe limbs.
    The softer plastic absorbs the excess dye & I doubt there's any remedy for it.
      • 5683
      What if I used nail polish? Or vinyl paint?
        Lurking About
        • 34218
        Are you reusing the body for a bare legged custom? If not, just redress it and forget about it. Dye is there to stay.
          • 5683
          No, he's not being used for a bare legged custom.
          I'll just put the jeans on him and forget it.
