FTC body mods/repairs, tips, tricks, chains & whips
This is a sticky topic.
  • Johnny lavalgo
    • Jun 7, 2015
    • 4
    So same problem as me. I emailed FTC too, many times, they never answer. In fact I think they don't care about problems with this toy line and same thing about their customers. Just poor sellers!
    • K
      Fun Will Now Commence
      • Jun 20, 2001
      • 2524
      For the female CTVT restringing to correct the hunching: were there originally photos in that post? If so, I can't view them for some reason.
      EDITED TO ADD: weird! I copied and pasted the post into word for printing and the images are there! WOW! Thanks , folks!
      I LOVE CHEESECAKE!!!sigpic
      "...and the Geeks shall inherit the earth."
      • TRDouble
        • Jul 10, 2012
        • 2544
        Another wobbly head fix...
        That's a beauty. Another trick for the head wobble is to boil it, slide in a pen or marker to widen it, then pop it in the freezer. Once it's cold to the touch slide the pen/marker back out and the plug will hold some of the stretch. I had to do it to a Flash head I just got from their loose selections a few days ago.
        • toothaction
          • Jul 15, 2017
          • 714
          Just picked up my first FTC toy, Mr. Freeze. There is much that I like about the look of the doll, but I have some concerns about the actual construction of the figure - it is very difficult to stand and pose, as the stringing seems to be very loose, and the head plug seems to be just a little too small for the provided hole, so the noggin wobbles and spins quite easily. Pardon my ignorance, but are there easy fixes to either of these issues? I like to actually fuss and play with my toys, but grew so frustrated with this new fella that I almost immediately popped him into a sitting position and left him on the edge of a shelf...
          >>> Looking for a few Bif Bang Pow! pretties. Please click to see if you can help!
            • 15631
            The most immediate fix for the head plug is to take some electrical tape and cut off about three inches worth and tightly wrap it right around the edge of the plug itself that grabs inside the body. You're not wanting this to show when you put the head back in. That should alleviate any wiggle room and give it a snug fit. Let me look at mine for the balance and see if it suffers the same. I'll reply back with my findings.
            • Scott Beatty
              • Feb 15, 2011
              • 8
              Does anyone have a tip for removing the clear glue/rubber cement that FTC uses to attach certain accessories (glasses on Harry Potter, etc.) to the Mego repros? I have a Green Arrow that has a small dollop of factory-applied adhesive on the costume that was used to keep GA's belt from the quiver in place. I want to get rid of it without using chemicals or undressing the figure. Any ideas?
                • 19471
                Gah! Why the heck did they do that? I"m not sure what to suggest with the suit still on--rubbing alcohol is useful and pretty safe.
                • markp67
                  • Jun 22, 2010
                  • 54
                  A rubber cement pick-up will take it right off.
                  • TRDouble
                    • Jul 10, 2012
                    • 2544
                    Fixing the posture of a FTC female figure using pipe cleaner... from comicmike!
                    I must profess that I had my doubts about the announcement 12 inch figures, but not THIS ONE! She stands up straight! No floppy limbs or waist. She's wearing panties! That was a bit of a shock seeing as none of the other female figures did. Her sculpt is a dead replica of their more generic heads, but with rusty red
                    • DaniellePlaysWithToys
                      Youngest Mego Fan
                      • Aug 30, 2019
                      • 267
                      When I read "chains and whips" I thought of Catwoman.
                      FTC apologist, Hawkman stan, and Cybatom shipper.
                      • TRDouble
                        • Jul 10, 2012
                        • 2544
                        Fix for FTC Muscle Body Arms
                        For the FTC Muscle Body with arm issues:
                        Originally posted by MIB41
                        There's an easy fix for that. When the factory hooked the arms on, they turned the arms the wrong way twisting the band, resulting in the spring effect. Pull the outfit off the arms and turn both the arms counter clockwise. This will alleviate the spring action and they'll operate and pose as normal. That's how I received mine and that immediately fixed him.
                        • KingKickass1983
                          • Jan 19, 2019
                          • 595
                          Does anyone know if the S type regular legs would pop onto the Muscle type S bodies hips?
                          Wanted:
                          Diamond select Spider-man hands. Long shot, I know...but ya never know..
                          • scott metzger
                            • Jul 9, 2007
                            • 2122
                            #28
                            I've actually taken to ditching the metal hooks for the muscle body arms altogether. They are not engineered like the originals, and they're always off center. I just restring right through the arm holes after wideneing the shoulder hole a bit (better fit makes them hold a pose better).
