Help? Will Type S neck hole be too big for FTC KISS heads?
  • =DAMAGE=
    • Sep 3, 2008
    • 7
    I am interested in ordering the Type S deluxe upgrade body to give some FTC KISS figures more pose ability, but I am concerned about the neck hole size possibly being too big? I have done a swap with a vintage MEGO type 2 body and the FTC head falls right out. I then did the swap keeping the head in the original torso replacing all the limbs and this worked but like I said I would like the pose ability that it seems that the Type S Upgrade gives. I realize that the construction of the Type S will not allow me to keep the original torso. Anybody out there use the Type S for any FTC figures? Thoughts?
    • 2722
    I wonder if a washer could be attached ...stuff the neck plug thru the hole in the washer and then insert the washer so it is below the neck opening.
    • cockyhoskins
      • Jan 13, 2009
      • 920
      I use S type bodies on all my FTC Kiss figs. They fit just fine. I've broken a couple heads removing them (even after warming them up), but I've had no problem with the fit on an S type body.
