Possible Solution to Bobble Head Problem? Inquiring Mind Wants to Know
  • filmation batman fan
    The Man of Many Voices
    • Aug 30, 2005
    • 964
    I saw a post on this forum that someone had placed a Mego head from FTC on a Dr. Mego or Classic TV Toys Mego body and he said that fixed the problem. I am wanting to tighten the heads on my Super Friends figures and I was wondering if that will do the trick. I noticed that CTVT has the heads and outfits of the Super Friends and Legion of Doom with the exceptions of the Wonder Twins. So before I invest or spend any money, I was wondering if I could get confirmation on this statement or if this was just a rumor.
    Many Thanks and Cheers.
    • 25680
    I can't say if the Doc Mego necks are smaller/tighter. I have used two approaches. If I am feeling really apathetic, a winding of tape usually works. If I have some extra time, I boil the head and stick something tubular in the neck to stretch it out, and then install it. I have a garage full of all kinds of junk and I just find something that works.
      • 19458
      Ponytail bands. Quick, clean, reusable.
        • 6546
        Agree with what these gentlemen have said. There are lots of good reasons to swap off the FTC bodies, but this isn't one of them. There are far easier ways to snug up a neck plug.
          • Aug 30, 2005
          • 964
          Okay. Several questions since I have never done this before.
          1: Where can I buy them?
          2: Are the expensive, affordable, or somewhere in between?
          3: Do you pop off and remove the heads first or do you insert these bands on with the heads in place?
            • 34211
            ^^ Walgreens, probably a buck a bag, and you just put them on the neck in the groove that meets the body and reinsert.
              • Aug 30, 2005
              • 964
              So you do remove the heads first?
                • Aug 30, 2005
                • 964
                Thank you PN Gwynne. It turns out I have some. I used them to keep glasses and sunglasses in place on Mego figures. I've already crammed and jammed these invisible elastic bands in with the heads and it did the trick and tightened them up. My hands are sore as all get up from the work, but it's well worth it. Thanks again.
                  • 19458
                  Sorry for the late reply. I remove the heads first, but leaving them in and using tweezers and a small flat screwdriver might also do.
                  Glad they worked for you.
