Type S Body Hand Swap Question
  • amby87
    • Nov 21, 2009
    • 42
    Hi,
    I recently swapped a Mego Soldier Ape head and outfit onto a Type S brown body and think the fit and look of it is great. Even though they don't match the body exactly, I would now like to swap the ape hairy hands onto the Type S. Has anyone tried putting original Mego hands on their type S bodies and, if so, do they fit? I remember a thread somewhere here where someone used shrink tubing on some type of hand (can't remember which manufacturer) to make it fit in the Type S wrist socket snugly. Sorry for trying to take the easy way out here by asking instead of just attempting it myself.
    Thanks,
    Joe
    • 34211
    when removing the Castaway hands heat up the arm first, they hand stems are VERY brittle(the one problem with these bodies, should have been softer plastic). The Mego hands should fit since the stems are a little bit wider than the Castaway ones.
    • ZICA
      • May 7, 2006
      • 2330
      I had to assemble and dress 103 figures for a recent project, all of which I had to remove the hands from the bodies first before the clothing would go on easily. That's 206 individual hands that I had to remove from the arms on Type S bodies, and not ONE hand stem broke. We've sold thousands of these bodies at this point and the number of people who have had issues with the hand stems breaking is still in the single digits.
        • 34211
        without heating in hot water first I've broken 2 glow hands and two flesh ones out of 6 bodies. Now I always heat them first and don't have a problem.
        • darkbros
          • Jul 3, 2012
          • 1359
          I've never had to heat any of the hands on either the bodies I got through the KS ( inital white, GLD)
          or the ones bought after ( Transparent, White and Brown).
          They simply swap out easy peasy and is the #1 thing I like about the Type S Bodies!
          My only issues to date has been
          (1) CTVT suits don't fit on them ( CTVT's fault, not Craig or Dave's)
          and (2) I've had to dremel a bit around the neck hole to make some heads fit so that they could turn
          (LJN heads, Mattell Retro heads).
          So I'm in the thousands of successful cases/ bodies sold, ymmv.
          • pmwasson
            Maker
            • Sep 12, 2007
            • 4865
            Originally posted by ZICA
            I had to assemble and dress 103 figures for a recent project...
            I hope this is something for Mego Meet!!!
            sigpic LaserMego
            • amby87
              • Nov 21, 2009
              • 42
              Hey, thanks for the advice! I tried it and the original Mego hands fit perfectly. I now have a very sturdy, super-articulated soldier ape and no worries about rubber bands wearing out. Thank you so much!
              • TRDouble
                • Jul 10, 2012
                • 2540
                I've had one stem break on me from the first batch of bodies sold at the store. I was then told I should apply a little heat before swapping hands.
                The last batch of Type S figures I bought has a warning sticker on the box that reads:
                "IMPORTANT!
                It is highly recommended that heat be applied to any removable parts before attempting to detach or reattach them. This helps soften the plastic which reduces the odds of the parts being damaged."
                • Vinny0026
                  Year Five!!
                  • 3724
                  I have to admit - on the flesh bodies I have never had the stem break in about 25/30 attempts
                  Now the clear bodies - It has happened 3 out of the 10 bodies I had
                  I do admit that I was in a rush when I broke 2 of them just tried to pop them out.
                  I never complained - I just got the dreadmill out - but it is a pain in the arse digging the stems out- sucks.
                  The boiling water trick is the best IMO. (Boil water - than dip the arms in for a few secs at a time, do this about 5 times - and than just pop them off)
                  I just got a few more in the mail the other day and now it clearly says on the outside of the box to heat them up first.
                  • astro-greg
                    • Mar 8, 2010
                    • 100
                    I had two hands break rom the first batch of bodies sold. I did't bother reporting it because I had extra hands (thanks to your awesome designs
                    But I recently had a forearm pin break when a figure fell over. The pin snapped when he landed on his face. I was surprised that it broke, and am not sure how I am going to fix it as getting the pin out of the upper arm is nearly impossible.
                    I may just wait until the new arms become available.
                    • David Lee
                      The Fix-it-up Chappie
                      • Jun 10, 2002
                      • 6984
                      Heat up the arm with the broken peg inside and then use a thumbtack or ice pick to pry it out by sliding the instrument inside the hole and prying up against the broken pin.
                      Dave
                      • Paladin
                        • Oct 26, 2015
                        • 96
                        Sorry to revive an older thread, I just wanted to throw this out there. Quite a few customizers have advised to use a hair dryer instead of boiling the parts. Some plastics are affected by the hot water and can become brittle. Not sure if these are made of the same stuff or not, just passing along advice that has served me well at my workbench.
                        • actjac01
                          • May 17, 2009
                          • 369
                          When I feel I have the need to heat, I always use a hairdryer.
                          I find it's just neater and faster to work with, and not quite as cumbersome as boiling.
                          I've used both methods. To each his own.
                          "...You can capture the Klingon & bring him back to the Enterprise!"
                          • dr_cyclops
                            One eyed, wonder
                            • Dec 17, 2009
                            • 2138
                            I've used both boil and pop and hairdryer and pop. I've broken/ripped more pieces than I care to count.
                            *Edit: I have not done any customizing with my current collection of CastAWay bodies. These bodies seem to be well made.
